E36 Starting Problems
pezo
Hi all not been on for a while mainly because i've no problems with my BM until today!!!! on turning the key to start all electrics are fine and work but there isnt nothing when you go to turn it over...??? Any suggestions would be welcome as it's kind of confusing.... hope someone out there can help :-)
Maybe starter motor? If you can locate the starter motor in the engine bay then give it a few taps with a plank of wood or something it should start up, had the same problem with one of my old E36s!
Hope that helps!
As you look from the front, it's on your right-hand side below the intake attached to the gearbox ;)
BTW shame on you for not visiting more often LOL :P
+1 to Jas and Def +1 to Dabsy, remember when i was going out with my missus and she had a Sierra saphire and her starter solenoid went and showed her the famous hammer tap on the solenoid to get it started.....earned some very good brownie points ;)
Defo give the starter a tap or 2,or another way is to put the car into gear,handbrake off (unless on a hill,lol) then get out and rock the car back and forth a few times,that usually releases it too :)
+1
      04 525d
    2. 4
      2e47 & 2e41
    3. 4
      2e47 & 2e41
      Resonator assembly clip
    • LesAshmore earned a badge
    • Droffilc earned a badge
    • Robbawdie earned a badge
    • Kev Miller earned a badge
