I've Just Bought My First Beemer - Help Required!
Thanks Greydog! I have not tried the battery unplug. But I have purchased Autel TS508 to try out and it found the error below from the ODBC scan. I tried to erase the DTC from this menu and the TPM is working again until I left the car for a few hours. Does anyone know what is causing the error? Thanks! -
No boost and strange noise
Many thanks for your input Dave. My car does have twin turbos. I checked for play on the cold side of the larger/bottom turbo by removing the air intake but I take your point about the hot side taking more of a hammering. I can feel the actuator move at the vacuum box but I can't access or see the point where it connects to the turbo. I don't know if the flap moves freely - maybe the hot side is full of carbon as I tend to do short trips. Time to dig deeper so I've just dropped it off with a local turbo specialists who say they can run diagnostic tests and do a route cause analysis. The car has only done 55,000 miles, full service history with oil/filter changes every 4000 to 5000 miles so I'm hoping the turbo hasn't failed already 😟 Thanks Jim -
Hi Darren Think about how much you have saved at Main Dealer hourly rates 😁 Plus the satisfaction of a job well done Modern cars not designed to be DIY friendly 😅 the cynic in me thinks it is a ploy to drive us towards the dealer network. They will probably tell us they would never do that, yeah right 🤣 Well done Dave
