Absolutely Awful Modded Motors.....
12
12
12
Hi guys, appreciate this topic is a bit dated, but within 6 months of owning my X3 M40d on 21" factory fitted run flats, and the state of our A & B roads, I've shelled out £700 on TWO tyres, due to the sidewall rupturing, leaving me stranded roadside and in need of a flatbed...not good. I'm looking for a back-up plan as we tour long distances on holiday and found an X3 space saver, claiming it fits all size wheels. BMW dealer was vague when I asked if it would fit....no surprise. The Wheel Shop said...check with the dealer. Wondering if anyone out there has more experience. Thanks all 19" BMW X3 G01 | Space Saver Wheel | The Wheel Shop -
5
Hi Dave, I’ve actually gone for EBC grooved discs with yellowstuff pads. Just thought it would look a little beefier whilst still benefitting from good performance and longevity. Stu👍
