320 I 1993 Auto Coupe :problem.....
theeflash1
BMW 320i E36 AUTO (1993) Ovefuelling problem after I accidentally put too much engine oil in car.
The wiring diagram states that the Relay is switched from the ECU. Is the ECU in this car a SRAIGHT PLUG IN or CODED(Dealership Job)..?
Thanks..
Kenny
Have much did u overfill it with oil?
As long as u ddnt experience 'piston slap' u may hopefully of gotten away with it?
Over filling can cause all sorts to fail.. Mostly gaskets..I can tell u this from experience lol
Is it overheating at all? Exhaust popping Or smoking as ian suggested?
Have a quick check of the spark plugs..
With regards to the overfuelling this will probably be the fuel to air mixture which will cause it to run rich.. Average i think is about 14.7 air to 1 fuel.
ECU's not doing its job right or could even be a dodgy MAF..not allowing enough air in.
Im thinking out loud here so Ill do a bit of research for you because im slightly confused =p
      New Car New Questions
      Faulty drivers door handle
    5. 0
    • olly530i earned a badge
    • StuMc earned a badge
    • MikeDT earned a badge
