Help Smoke And Oil :(
help smoke coming from drivers side of engine look like it is coming from side and back of engine and some oil :( just poped to B&Q came back and noticed the smoke coming from under bonnet any ideas guys :(
Smoke or steam?
Smoke = oil leak dropping onto exhaust.
Steam = water...
Be careful though, it could be a short that is burning the wiring.
Run her from cold and watch with bonnet up !
Maybe let her cool and place your hand behind the head to see if it leaks from there, otherwise it could be sump gasket leaking onto exhaust !!
Is there a puddle when stood?
Without being there I would initially guess a crank or cam seal failure...
Let us know what makes yer hand wet LOL
hi its not water def oil and smells of oil burning had a feel found some oil at back and side of engine but not much i take it for another drive and it did not do it very strange but i can see small drip from underneath
had a good look to day i can see it on the exhaust running down but cant see where it is coming from :(
is it a 4.4 or a 3.0? of a D?
I guess its a rocket cover gasket
hi its a 4.4 52 reg could be im getting oil round the oil filler cap wipe it off and it comes back at first i thought i did not put cap on properly
New cap or cap-seal. It'll run crap with a poor oil-filler cap.
I'm a poet and didn't know it !
oil leak was rocker cover gasket all sorted now but got car back and temp control panel has gone from Celsius to Fahrenheit any ideas how to change back
