Clunk/knock When Pulling Off
mavis x5
hi new to the forum so hi everyone.i have had my x5 for about 6 weeks and its started making noise sounds like it is coming from rear as i pull of it makes a clunk/knock noise then it is OK drives fine all gear change is smooth its only just when pulling off :( any ideas guys.
it is a 52reg 4.4 thanks Dave
  • 1 year later...
My guess would be rear sub-frame bushes a common problem around 80k upwards. They are not a nightmare job OEM will cost about £80 to £100 a set depending on where you buy, I changed mine for Polybushes £195 a set plus £45 for tool hire (bush puller) I changed the rear spherical bushes while I was under there £29 a side. I am an old bloke and an average DIY er but the whole lot took 5hrs with tea breaks.
Good luck
    2. 12
    3. 12
    4. 5
    5. 5
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
    • Damion earned a badge
      Reacting Well
