Parking Sensor X5 2002 30I
andyx5
just noticed today that my rear parking sensor's aren't working, when i select reverse i get a beep from inside my car but nothing else. how do i check to see if there working correctly, any help would be good.
It maybe that one (or more) of the bumper sensors have failed or are faulty.
Someone will be along shortly to help you diagnose which one(s) if any...
just been reading on a couple of forums that there should be a ticking noise coming from the sensor's when you push your thumb tight against them, just tried this and 3 out of 4 are ticking, would the one that's not ticking cause them all not to work?
what i need to no now is if i replace the dude one will they work again?
If you're lucky! After replacing 2 rear one's on mine I found another one on the front faulty as well! But then I'm just lucky like that I suppose! :(((
  • 2 months later...
Ign must be on. Once you've selected reverse, put it in neutral, or just push the button on the dash to activate the parking sensors.
It stays on until you drive off then shuts off automatically - or you can switch it off on the dash button again.
  • 3 months later...
      M buttons
      Steering wheel replacement
      F30 A-pillar install
    • Conmil earned a badge
    • Loulou earned a badge
    • Robbawdie earned a badge
