Clunking Noise From Under Car
stebaz47
keep getting clunking from under car when going over uneven ground.
did front drop links still the same ,looked at track rods wishbones ,sturt mounts all fine
does any one no what this could be
thanks steve
Wow not going to be an easy one to find, Does the clunking sound like metal on metal? It`s well worth putting the car onto axle stands then go around all the joins with a crow bar, the slightest play can make the strangest noise. Is it coming from the front or back of the car, if it’s the middle it will be a center bearing!
How about trying something simpler like, wheel nuts, bearing tightness? Maybe look at the shocker rods for seapage/damage? Just a thought because you seem to be trying everything else!
Could even be a caliper/pad/handbrake issue ?!
      2007 Z4 alloy wheels and tyres
      E63 635d Auto - Transmission service.
    3. 4
      Locked out of a 1990 525i
      INPA / ISTA / Coding help - How and what to get?
      Hey BMW and Windows 2024 X1
    • ARoosterinaRoadster earned a badge
      Collaborator
    • Abjwsm earned a badge
    • DHTL earned a badge
    • Bluebeard earned a badge
