Timing Chain
tony w
Hi I have just bought a e30 320i 1984.the service record states that the cam belt was changed at 147k the car has done 150k, i was told that this car has a timing chain (by the seller)that never needs changing. i get confused with timing chains and cam belts so is the cam belt and timing belt/chain one and the same and if not does the chain need replacing as there is no record.
thanks tony
If you trust the service record then @3k this belt is fine for another 30k+, I personally hate cam belts and I always replace them when I buy a car (just for peace of mind)...
thanks for the reply, i also hav a receipt from the garage that did the job in 2010 detailing the parts used and the cost £246 so i am reasonably happy with that.
Sounds good to me. I would personally give it a quick visual inspection but typically, thats fine
