X5 3.0D 06
Hi
Can anyone help. The bushes on the passenger rear tyre r making a very noisy squeak. Unfortunately there is not one bush on this wheel there is several. So, other than changing each one is there another method to fixing this issue.
Thanks for ur help (hopefully).
Ps I've tried oiling the whole lot it's not made a bit of difference.
If you're gonna change ONE, then you should really change them all... In my opinion ;)
Dabs is right, but this can end up one big bill as Prestige knows.
At least, if you change one bush on one side, make sure you change the same bush the other side.
But...
In the end you will end up replacing all bushes if one or two have started failing.
      wheel fitment
      Front windscreen washers
      wheel fitment
    • Loulou earned a badge
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
