Engine Stutters
jesserinck10
So since im on here for audio problems, i thought i would ask if anyone has had any problems with when you go to say pass someone the engine kinda starts to sputter. Not a real smooth acceleration if you put the pedal down. But when you let up it kinda smooths out. Thought it may of been plugs and replaced them but didnt solve problem. Does fine on highway driving but it just acts up if you wanna get up and go! Any ideas? Its an '04 325i
Mine is doing exactly the same at the moment... Running too rich can cause this, but it can be a little tedious finding the source of the problem - MAF, TB, TPS, Cam sensor, Fuel Pressure, Filtering etc... Has to be one, or a combination of these !!
BTW My symptoms are :
Accelerator too far = Massive hesitation... Back-off a little and it somewhat returns !!
Heavy MPG !!
Not much help at this stage, but just have a look at the spark-plugs and let us know the results ;)
      BMW 125i E88 - Passenger Mirror Fault (RHD)
    2. 6
      LED adaptive headlight / high beam failure warning
    3. 6
    4. 6
    5. 6
    • G1000 earned a badge
      Reacting Well
    • AAJS earned a badge
    • Paul Ibb earned a badge
