Amp Wiring
Look behind the engine my friend... There should be a few bungs, either blank or with a bit of loom thru...You can use the blank one by piercing it and passing your wires through to the internal footwell !
Generally speaking, the majority of BMW batteries are in the boot with the jack, behind a pull down trim panel... But there is a Juicy main live "Jump" terminal under the bonnet :)
      M buttons
      Steering wheel replacement
      F30 A-pillar install
    • amebb went up a rank
    • Conmil earned a badge
    • Loulou earned a badge
