Cant Decide Black Or Blue??
Steering wheel replacement
Morning Connah Welcome to the Forum Not sure what you are trying to achieve here ? If your OEM steering wheel has paddle shifts it should be fairly straight forward swap even though the replacement will probably be Aftermarket. Just make sure you can get support from the seller and they accept returns if it didn't fit If you don't have paddle shifts there is the small issue of how you can get the shift to work, it will involve loom extensions and programming at least. If you just want the competition look and are not worried about the operation then it becomes easier Good Luck Dave -
F30 A-pillar install
Morning Shawn Other than checking www.realoem.com and the Internet for help, it's not a job I have done but that would be my starting point. Perseverance, patience and practice may help as well 😅 plastic clips are easy to break if they are not spot on with alignment. I buy spares before starting any job that involves taking trim off, try trial fitting the clips off the car gives an idea of alignment and pressure needed I have used a little Washing up liquid as lubricant Good Luck Dave -
I removed the driver’s side a-pillar in my 2013 320i to make sure the sunroof drainage tubes weren’t leaking behind them. As easy as they are to get off, what a pain to put back on. I ordered new plastic retainers because both broke. Does anyone have any pointers for getting it back on? I fought with it for an hour with no luck whatsoever. -
Hi Does anyone know where I can get a steering wheel replacement with a flat bottom and paddle shifters for a 2012 320d I have found a few but not too sure whether they'd be compatible any help would be appreciated. Thanks -
Front windscreen washers
Yay glad it's sorted Donna just needed the right Tool on the job 🤣 (Been there a few times) Dave
