Update: Bad News
Guest DazH
Hi guys,
As you would be aware by reading my posts, I've been stripping my M20 down and I've just got the cylinder head back from the engineering place after a pressure test. the Hex-Bolt that snapped off had fired down through the cylinder head it's self and made a hole in it. Cylinder head is a right off. In all honesty, I don't know what to do..
I contemplating a new engine. I have found this H23 Hartge 2.3ltr M20 from an E21 online. Can anyone tell me if this will fit with my current standard transmission? And if so, Will I encounter any problems actually getting it in there?
I appreciate anyone's help,
Daz
Hartge: http://www.carandclassic.co.uk/car/C146979#
That REALLY is bad news Daz... I was right about the bolts but i wouldn't have thought of that much damage unless they were shot for quite a while !!
what about a recon head?
I'm waiting on a few quotes for a recon head. What do you think of the Hartge engine? It came out of an E21 3 series but that shouldn't really matter right?
Depends on the engine management system tbh... Should be plug n play but....
I agree Dabz, I'm stuck at the same part you are. The "But...." bit
      Buying an X1.
      Buying an X1.
    5. 4
      Rear knocking
    • LRR earned a badge
    • BobW earned a badge
    • Clunk 84 earned a badge
    • Neil M earned a badge
    • oldnotbroken earned a badge
