Is This Right?...
Guest DazH
Guest DazH
Removing the intake manifold and expecting to remove 3 bolts, There was only one. Surely that's not right... right?
Also, Is there usually a gasket? as again... Nothing, just metal-on-metal...
Daz
Guest DazH
Am I correct by saying that this lil fella stops/reduces blow-by, which would explain all the oil in my Throttle body? Surely it not being bolted to the intake manifold with a gasket would not allow it to perform its job?
I'm trying everything to move the subject from 'Ow Darren, looks like your piston rings are fried' to 'Yeah, it needs a gasket and new bolts! :D'.
Daz
Guest DazH
BUMP!!
Sorry, I needs help! cars outside with half its engine ripped out. I'm sitting here with a can of Gunk and a toothbrush HAHA
Daz
That looks like the Plenum chamber which mixes the fuel/air.... Looks a botch too, without bolts n gasket ! That will leak air very badly !!
      Buying an X1.
      Buying an X1.
      Rear knocking
      645ci coolant
    • LRR earned a badge
    • BobW earned a badge
    • Clunk 84 earned a badge
    • Neil M earned a badge
    • oldnotbroken earned a badge
