5 Series 2005 Rear Brake Pads And Discs
starturbo
Hi guys.Has anyone replaced their rear discs and pads? I hear the pistons have to be 'rotated' back into the caliper and if you go too far you can break them. Is there any truth in this? I can get the parts for £100 and a local dealership want £300.Daylight robbery.
Same with all rear pistons mate, they have to be rotated in.
I usualy do mine with a G clamp, but propper tools can be brought.
If you havnt done this before, do some good research, as brakes are a major problem if they go wrong :)
As Gav says but they don't need rotating!! Just loosen the nipple and push it back in... If you get substantial resistance then remove the caliper and service it - Mucho, mucho grande cheaper than a replacement !!:rolleyes:
      Buying an X1.
      Buying an X1.
      Rear knocking
      645ci coolant
    • LRR earned a badge
    • BobW earned a badge
    • Clunk 84 earned a badge
    • Neil M earned a badge
    • oldnotbroken earned a badge
