E36 Engine Swap Gone Rong
Driftslut2010
you need to get hold of the ecu for that engine also there is a small black box which is for the imobiliser just under the steering column i had the same problem the only way i solved it was buying a donor car with the engine running i swaped the ecu and wiring loom + the little box under the column the car started straight off the key
      Power Message
      Folding mirrors
      Centre console iPhone charger
      Folding mirrors
    5. 3
    • bill gall earned a badge
    • kor earned a badge
    • Damion earned a badge
      Reacting Well
