How to adjust parking brake shoes
Took me 2 hours yesterday, and a joy to do compared to myy old car.
Tools Needed
Jack and axel stands
Breaker bar
Wheel !Removed! (house bricks)
Flat head screw driver
Ratchet
long ratchet extention bar
10mm deep socket
17mm socket
16mm socket
6mm alan key socket thingy
Step 1
Slaken wheel nuts using 17mm socket and braker bar.
Place wheel chocks at front wheels
Jack car up and place axel stands where the rear side jacking points are.
You can, however, do both sides independently...
Step 2
When car is sucure, remove boot from around handbrake lever, just give it a tug and
pull it upward towards the front of the car so its out your way.
Step 3
Use 10mm deep socket withe extention bar to loosen the brake cable nuts until the cables
are completely slack.
Step 4
Remove wheels, place next to the discs to the rear of the car(for putting callipers on later.)
Step 5
Remove callipers, there are 2 16mm hex bolts holding it on.
Place on wheel next to you, dont let them hang
Step 6
Remove discs, take out the 6mm bolt on the disc, give the disc a tap all round with a rubber mallet
and the dics should come off easily.
Step 7
Now you con see the shoes and the adjuster, circled below.
On the right wheel, turn the adjuster down and towards the front to expand the shoes.
Ont the left wheel, turn the adjuster up and towards the read to expand the shoes.
Step 8
When its difficult to put the disc back on because to much expansion, take 5-8 clicks off
the ajuster.
Step 8
Put discs, calipers and wheels back on.
Step 9
Pull the hand brake lever several times to seat the cable.
Then pull the handbrake up 2 clicks. Tighten the cable tension
ajustment nuts until its just possible to turn the rear wheels
with a littke resistance.
Release the handbrake and make sure the wheels turns freely.
Step 10
Pull up handbrake and check wheels are locked.
Put boot back on around lever.
Lower car and tourqe wheel nuts up.
Done :rolleyes:
Edited by Dabsy
Alternative
  • 4 months later...
The 2 nuts on the lever? yes..
Jack the back end up, put 2 clicks on the handbrake.
When you can feel the road whells being gripped by the handbrake, take a little off the nut, job done.
Bare in mind though, i changed shoes, cables the the lot on mine, it still dont hold on the drive, e46's are bad for this
Excellent write up Gav...
As for my car... If you need to adjust./change the hand/footbrake cable- you have to REMOVE the exhaust AND the heatsheild before you even think about any cable changes lol
its a barsteward on a seven... sorry to hijack, but it needs saying...
Just to add...
We all know that any BMW handbrake will JUST pass an MOT, they are NOT the best but do work some lol...
The handbrake shoes will last the life of any BMW!:mellow:
For your info...
A Brake pad sensor needs an earth to transmit a failed brake pad...
It's earth will be the disc or caliper...
Check the pads- if ok then the sensor(Wire) has earthed prematurely...
DAZ ;)
For your info...
DAZ ;)
Quite the opposite on the E46 mate
The brake pad wear sensor is a simple closed circuit, when the pads run low/faulty sensor/sensor wire damaged, the circuit is broken, therefore displaying a light on the dash. B) ;)
  • 4 months later...
Great price reduction for giuseppe zanotti shoe and giuseppe zanotti shoes on sale, free shipping for worldwide, full cash back promise. Free Shipping!The advantage of our Giuseppe Zanotti Shoes is high quality and low price.
  • 3 months later...
You can adjust the shoes with out taking the disc off just using a flat screw driver and a torch.If you look through one the bolt holes on the disc you will see the adjuster,adjust acordingly using the torch because it is dark lol
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
