Hi Dave,
I’ve been told about how BMW will just sell a complete turbo unit which I can imagine will be very expensive.
I will have a look on that website and thank you for your help, it’s really appreciated, cheers.
Hi Zeke
You may need a Turbo Specialist for this as BMW do't repair anything they just replace complete assemblies
Try www.realoem.com if you aren't aware it is a BMW online parts list either put the part number in the search box or the last 7 digits of your Vin it will call up your model but as said above a BMW Dealer would charge for and fit a complete Turbo assembly
Good luck
Hi everyone. I have just joined this forum as I have just bought my first ever BMW (Its the 320i 4 door). It is getting prepped by the dealer but part of the deal was they will fit a rear spoiler to the car for me, but I need to provide them with it. I am looking for something subtle, in gloss black and good quality. I like the one below with the cut in the middle. Any advice/guidance which one to buy please and where from?
Morning Stu
Sorry it took a little while Friday afternoon had to nip down to Wincanton Saturday Judging a Gundog Working Test and yesterday Dog Training day (you jinxed it with your Slow day)
So very confusing while the Wiring Diagram shows the rear lower tailgate lock and actuator button it doesn't give wire colours (pictures attached) I checked the Bus system that didnt help either according to the wiring diagrams all pre-facelift models (up to 2004) should be the same
All I can think is either there is a short somewhere (through robber cable gromit at the top)
So not sure if it helps or not
Looked at the PDC and it points toward the PDC controller (in the boot down by the battery)
Hi everyone,
I have a 520d lci auto and the actuator is on the way out as even when parked it’s on boost as it flutters when I turn it off. I’ve had a trusted mechanic have a look and he said it’ll be the electronic actuator playing up but when I look for a new one there’s different numbers on what look like identical actuators. I will attach a photo and it the 2nd row of numbers that is always on each actuator but the top and bottom row are usually different which I’m unsure which one will fit as I’ve been told by others that the actuators from the manual and automatic cars are different
Thanks in advance for any help.
