F10 2012 A/C vent actuation issue?
Hi - long time owner, first time poster...
My A/C is only working for about 30 seconds and then although the blower continues (I can hear it loud & clear) the vents all shut and no cold air goes through.
If I switch the A/C button off & then on again, the vents open - it immediately blows lovely cold air and then again after 30secs the vents close. Any ideas? Seems like a vent actuation issue rather than a compressor issue.
No DTC error codes.
Morning Stuart
When you say no DTC which Diagnostic program was used ? As things do work even if it is a bit Eric Morecombe "all the right notes just not in the right order"
A bit of a pain but you could try cleaning the connector pins on the AC control unit with a good electrical contact cleaner. Or possibly if you have access to a BMW capable Diagnostic try rebooting the unit in case it's a software glitch
Did I really say "no DTC errors" - that's what happens when I try to do two things at once...
No ODB errors... I've unplugged the battery for 20mins. Let's see if that helps
