Window & Mirror Control Console Malfunction
2019 330D
Worsening issue with the window & mirror control panel in the drivers door.
Started with the one touch function on the windows not working, then the windows would not work at all when you press the buttons.
In time if you keep trying the windows will work although very intermitant and sometimes just stick mid way.
This is happening on all windows.
This has now moved on to the mirrors, they will not adjust then again intermitantly move.
Hi Nick
The Drivers Door Module is the master for all windows plus mirrors simple to change as it is plug and play
First make sure of the part number, use www.realoem.com put the last 7 digits of your Vin into the search box then search the Trim section for the drivers door module. Once you have the Part number carry out an Internet search for the best price.
Good Luck
Theme by IPSFocus
Bimmer Owners Club Powered by Invision Community
