New User Looking For Advice
Hi everybody I'm Craig with a e60 520d 2009. looking for some advice as to why my wipers dont work as they should.
I press the stalk in for intermittent use and the light comes on the stalk, the wipers work for one wipe then they stop. I can adjust the setting for sensitivity which activates the wiper one time again then nothing green light still on and no other movement of the blades. all other wiper functions work as the should. any help or advice would be appreciated.
Thank you
Solved by E60 520D
Hi Craig and welcome
My first thought is the rain sensor.
It is on the windscreen behind the rear view mirror housing.
Disconnect that and see what happens, if your wipers start working intermittently, there’s your issue!
Morning Craig
Stu is on the right track but when you push the button on the end of the stalk and the green light is on that is the rain sensor enabled, wiper should then operate when the sensor is obscured by water on the screen, just either spray water or sprinkle some on the screen. A single click down intermittent two clicks up for full operation and high speed a push towards the dash is intermittent rear wash wipe push towards the dash and click should give full rear wiper operation
  • Solution
Thanks for the comments guys. I removed the case around the sensor. I was unable to release the plug as it felt like it would break. With the green light on the stalk and while it was raining i pressed the actual sensor against the screen and blow me it worked, then it stopped when i released the pressure. So to me it may need removing so that i can apply a new pad to secure it to the screen. that will be my next move
Guy's just an update. I finally got around to removing the sensor and guess what it has no silicone or any other type of pad on it to secure it to the screen. would this be the reason it worked when I pressed it to the screen and is fitiing a pad the solution ?
