Battery
Apologies if this is in the wrong forum, I have posted in the Series 1 but despite many views I have no replies and I am keen to hear from anyone who can help.
I’m a new (6 months) BMW owner, it’s only taken me 50+ years! I was surprised to find that the battery is hidden away under the bonnet so identifying it is not easy. I believe it will be an AGM due to the start/stop ability of the car. The reason I ask is that my mileage is low and I am concerned that it will not be charging sufficiently. I am thinking of getting a trickle charger - Ctek - specifically for an AGM battery as I understand that a “normal” charger may deliver too much of a charge initially and in any case the specific Ctek one will limit the full charge to 14.5v I believe. I was hoping to charge via the 12v socket but I think that is not constantly live and so will have to connect to the battery. Any advice or comments would be appreciated greatly thank you.
Sorry Stuart,
Happy new year.
The battery is located on the boot on the 1 series I believe. There are charging points under the bonnet. A positive is usually under the red flap and a negative looks like a large bolt head.
Please correct me if I’m wrong.
Thank you, and the same to you. Yes, the battery is under the bonnet and well hidden (why?!) so I must assume it is an AGM as I cannot access it to see. I can use the + and - to charge as the 12v is not constantly live unfortunately. I just wondered if anyone had a similar situation but think I will proceed with my first thoughts and invest in the appropriate Ctek.
Theme by IPSFocus
Bimmer Owners Club Powered by Invision Community
