Condensation or something serious? Oil temperature
Hello everyone, just bought a bmw e92 325i 2.5l and i have 2 questions, first one is if that gauge under the rev meter on the dash is the oil temperature and if it is ok to fluctuate. For example when I am driving slowly, or in traffic that temperature is rising slightly to 80/90/100 degrees, however if I am driving constantly on the motorway at 70mph it drops to 70 degrees.
just wanted to know if that is normal or if there could be a problem and second is if the vapour in the video is ok or if i should worry, it still comes out after driving the car.
Morning Andrei
Welcome tot the Forum and Seasons Greetings
If oil temp/pressure is fluctuating and from the video I would guess there is a top end wear problem Valve guide seals or more. What mileage has the car covered what is it's service history
Jenksey on here used a Valve stem seal additive with some success but if things are split or really worn it would struggle to be effective.
Thanks for the answer, it has got 90,000 miles and some service history it is not full service history but it does have some paperwork, also i have to mention there is no misfires or any signs that something could be wrong just the smoke or vapour whatever that is. And it is the oil temperature fluctuating.
Hi
90 k is not a lot of miles when was it last serviced ? Are there any leaks anywhere?
So the vapour does it smell ? Sweet smell (could be anti freeze/coolant) has it needed topping up? Oil smell is obvious
Next check and test and change if required the Oil Temp sensor I believe it's on the Filter body on your model. See if that stabilises the Gauge
