Car won’t start when hot
Hello I have a bmw f21 when the car is cold it starts and runs fine but when it gets hot it won’t start and comes up with error code p0087 any idea please
Morning Shaun
We love Christmas puzzles 😁 but a few more clues may help us the code poo87 just tells us you have a fuel pressure issue ??
What engine is it ? When did it have its last service (not just an oil change) ?
Possible causes could be, (1) Faulty Fuel pump or Fuel pump relay (2) Clogged/Blocked Fuel Filter (3) Faulty fuel pressure sensor (4) Faulty fuel pressure regulator (5) Leaking or damaged fuel lines (6) Air/vacuum leaks on the inlet side
Those are just the simple ones that spring to mind, the code you have is a Generic code a Diagnostic scan with a BMW capable scanner may give more information. Always remember any code should be treated as a symptom not always the answer
Hope this helps
Have a Great Christmas
Hello mate thanks for the reply and sorry for lack of information.
I think the engine is a n13 I had the car serviced in may and when I pick the car up and looked at the invoice they hadn’t change the fuel filter when I questioned the garage they said the fuel filter is part of the fuel pump so I said don’t it have a in line filter and they said no
Thank you
