Hi guys just got a BMW 330d but i keep reading the DPF & EGR could end up destroying engine turbo etc that will clog everything eventually ,i had a 320d before this one had no DPF had that car 10 years with np problems any ideas will be appreciated thanks in advance .
Hi Ali
I hear a lot of talk about DPF/EGR issues in my experience normally from folks who drive the car almost into the ground normally short journeys so service intervals are extended (if it gets one) and then complain about the DPF/EGR. The others who talk about DPF/EGR issues are often selling a service that will hollow out your DPF then with some software tweaks get it running without warning lights. They don't tell you that if an MOT inspector picks it up it is an instant fail
On the other hand my own X5 3.0d has just past 135k with no issues my brother inlaws 540d estate has just passed 200k with no issues (both cars had the EGR recall early this year) Brother inlaws car is Chipped and way over 400hp and driven hard (which these engines love)
So reliability for the DPF and EGR will depend on what sort of driving you do and regular annual service as a minimum (I change oil at 5k intervals), if you do a lot of local short journeys at least once a month give it a good run at Motorway speeds
Hi Dave thank you very much for your reply very appricciated yes i do beleive in lower mile services also i wonder if my bmw had a recall or not i tried taking EGR off to clean but was stuck am guessing very caked in soot hence stuck i took out swirl flaps not like idea them falling in to engine but must admit lost bit of power on bottom end not had it mapped yet thanks again Dave . Ali
Edited by BMW LOVER
