Hi guys I’m new here having just purchased my first ever bmw.
I have the lights in the exterior handles but they don’t work. Anyone else have this issue ??
Hi Paul
As your car is basically new have you had a conversation with your BMW Dealer ?
Normally the door lights are as tough as old boots, my X5 2009 vintage has them and they all still work (that's jinxed them)
Hi Dave. I’ve been on to my dealer and they can’t confirm if they do or don’t have them. I’ve seen plenty with them with a lower spec than mine so I’m disappointed really. No glovebox light either. £50k and only half the bits are there.
Morning Paul
If you know someone who has INPA/ISTA just plug in and the program will let you know what equipment the car was built with (list and codes) your dealer could do it but it sounds like yours falls into the "can't be bothered to help a customer" category
You could also use a BMW Vin Decoder several online to pull up the same information
I must say I thought pretty much all top of the range Beemers had them so worth a search
Just had a reply from BMW uk
Hello Paul
Thanks for contacting the BMW Customer Information Team regarding the lights on the door handles and glovebox. I understand how frustrating this is.
I’ve checked your vehicle’s factory specification against the VIN you provided. The exterior door handle lighting and glovebox illumination are not part of the standard equipment on your M135 (F70) build.
The illuminated door handles only operate when the car is ordered with the Welcome Light/Ambient Lighting package, which was not specified on your vehicle. Likewise, BMW no longer fits glovebox lights as standard on this model.
If you would like further confirmation or to discuss retrofit options, we recommend contacting your BMW Centre directly.
You can find the nearest BMW Centre
here.
In the meantime, if there's anything else I can do for you, please let me know.
Kind regards
Minko
BMW
United Kingdom
Min Ko
Customer Information Consultant
BMW Customer Support
Summit ONE
Summit Avenue, Farnborough
Hampshire, GU14 0FB
Tel: +44 (0)1252 920317
Email:
[email protected]
Web:
www.bmw.co.uk
BMW logo latest
Can anyone explain to me what they are talking about when saying about welcome lighting and ambient please
Hi Paul
First check yourself using a BMW Vin decoder (if you haven't already) I work on the old "in God we Trust everyone else we check on principle 😅
There are LED light sources in each door light is fed to the door handle by a Fibre Optic cable, when the car is unlocked the area below the handle is illuminated they call them Welcome lights. Inside the car there are Ambient door lights above the door pockets and in some cases speaker lights
If your car was built without them you will probably find a Dealer sucking their teeth and explaining what a difficult job it is £££££
If they are important to you I would find a good BMW Specialist (there is a Register) and talk to them
The real question would be if the wiring/power source is there if it is then it should be a fairly straight forward retro fit and coding process
BMW have said I need to subscribe to digital premium apparently which I have free until February 🙈🙈
Hi Paul
So I would guess it is all there, I hope this isn't like VW with the ID3 where you have to pay a subscription to keep things like Heated Seats or Heated Steering wheels working !!
Keep us up to speed please
Yes Dave I’m told I have to get the premium bit but I emailed back and said got it. guess what …..no reply as of yet.
Had a reply from BMW after being told they should work. Than I got this
Dear Paul
Thanks for getting back in touch with BMW ConnectedDrive. I'm sorry to hear that you're going through this.
The BMW Digital Premium includes personal welcome from the Welcome Light Animation. It offers lighting effects for the front and rear lights. These animations greet you when you approach or unlock your vehicle.
The exterior door handle lighting are not part of the standard equipment on your M135 (F70) build, which is why it's not functional.
If you would like further confirmation or to discuss retrofit options, we recommend contacting your local BMW Centre. You can find the nearest BMW Centre
here
If you require any further assistance, please get back in touch.
Kind regards
Muhammad
BMW
United Kingdom
Muhammad Dawood
Customer Support Executive
Summit ONE
Hampshire, GU14 0FB
Hi Paul
There is me thinking that the M135 is pretty much top of the range with the 1 series why wasn't it fitted ?? Especially as the car has the rest of the so called "welcome lighting" package just doesn't make any sense to me
Is there a small clear lens under the door handle ?
