Hi, I have just replaced one of my headlights in my F21 118i 2016 and when I have tried them the colour is a different hue, I changed the ballast and modules from the broken light, how would I go about getting them to match, is it bulbs that would need changed or the lens/diffuser on the angel eyes, could I replace anything else from the broken light without removing the lens? Thanks for any help
Morning Graham
You say you changed the Headlamp did you change for a "new" or "used" unit if used is it correct for your car ? If you are not aware you can check www.realoem.com put the last 7 digits of your Vin into the search box the search lights
Realoem will also have small exploded drawings showing how bits fit together
