Hi Guys,
3 series f31 2026
Hope all are having a good weekend, I'm hit a small issue I bought a new camera (aftermarket) and have gone to fit and striped the front of the dash and found there is no RCA point on the NBT head unit now I'm finding different reports online I can't figure it out do I need a module to make this work am I looking in the wrong place? Any ideas or advice would be great, thanks in advance
Morning James
If your car originally had a camera fitted and the one you have purchased is correct for your car it should be straight forward. I have read that sometimes the trunk operating button needs changing (I have never done the job so can't comment)
If your car originally had the acoustic PDC with an image on the screen you will need control unit for the back up camera, that is what the camera plugs into. Then that module will need programming to the car so the screen receives the images.
Hope this helps
