Running Boards
Hi I need some help / advice please,I own a very nice 2012 X6 and what I thought would be a simple enhancement want to fit running boards…… Not as easy as I thought the market appears saturated with them so if possible has anyone had aftermarket running boards fitted and could steer me in the right direction
Morning Mick
First question why not OEM running boards ? You would then know they will fit here are the OEM parts and fixings
If you take a look at www.realoem.com put the last 7 digits of your Vin into the search box and it will bring up your model. Then search Body section
Once you have all the correct part numbers you can search the Internet for the best supply (remember you need Left and Right parts)
You should find parts from BMW Breakers as well as contacting BMW Dealers to see what their prices are like (sometimes a pleasant surprise)
Thanx for your response Dave I will follow up on your suggestions.
Cheers.
