Rear Washer
Hi all,
Ive just fitted a new rear washer pump which is now working as I can hear it... went to the back to see if jet was blocked only to find it is not fitted with a rear washer
seems very strange !!!20241010_100129682_iOS.heic
Hi Chris
Sorry can't open your Video
However if you check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model then check the vehicle electrical system section it shows the rear wiper assembly complete with Spray Nozzle
You will also see all the part numbers if you need to buy one you should find it under the rear spoiler above the back window I believe
Good luck
Thank you so much.... its got me baffled, must have had a new tailgate at some point
