Seems  my 520  estate  ,2013,    rear  suspension  needs  a  new  module  ...wondering  where  best   i  might  get  this ...also  what  sort  of  cost  should  be  as  in  as  much  as  i  can  see  prices  vary  a  lot  ?   ta  again  in  advance
Morning Frank
How are you so sure the car needs a suspension module? Not saying they can't fail but in a long time I haven't seen one that has.
Just take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model then search rear axel for the part you want or take out the one you have and take the part number from there. Once you have the part number Google for the best price and supply. Your choices are Second User or New
Ta  for  that  Dave  ....mech  seems  think   its  where  the  problem  is  ut  i  hear  what  your   saying  about  never  having  seen  one  fail ...  rang  around  today  and  found  out  its  main  dealer  only  availability  !!!   so  rang  them  ....never  told  me  sit  down  before  telling  me  price ........1440  euro  PLUS    vat ...  so  definitely  have  think  again  ...have  seen  converting  to   conventional   shocks/springs(?)  seems  be  what  some  owners  do  ..have  least    try  get  some  idea  what  cost  that  might  be  to do  that  before   decide   on  solution  ...   might  be  my  age  but   really  really  annoying how  they  just  made  cars  more  and  more  'complicated'  for  seemingly  no  reason  other  than  their  idea  of  progress....iv  rallied/rallycrossed  imps  on and  off  for  50  years  and  not  alone  is  their  suspension  all  round  very   simple/ effective and  inexpensive ...but  even  i  can  change  any/all  of  it  in  few  hours ...sorry  rant  over  ...
Thanking  you  again
Morning Frank
BMW do like to charge stupid prices🤣 in the UK you can buy a new one with warranty for around £150. 5 minutes to change a used one from £20 to £50 and as said I have not seen a failed one since 2001 (my first X5) Just remember BMW do not make these parts they buy them in.
BMW Air suspension is a fairly simple system 2 Fuses a Relay a Control Module a Compressor  2 Ride Height sensors and 2 Air Springs
The most common faults are leaks ? Leaking Air Bags. The next is Compressor failure the leak causes the compressor to run far to long and it wears out and can't produce enough pressure to lift a heavy car.
Your car is 12 years old so the suspension at an age where it could do with a refresh whether its springs or air. You need to know what the problem is. Is it Suspension going down and not inflating ? Is it compressor not running ? Is the suspension lopsided ? A Scan with BMW capable software would tell you/us more
My X5 is 2009 vintage I have just fitted a new compressor as the original was getting tired (over running) £140, with 5 year warranty. Both air Springs £160 with 10 year warranty whole job took me 5 hours on a Saturday morning I don't have a lift so all work was carried out in my home garage. If you cant do the work yourself you will need the help of a mechanic having software that is BMW capable is the only requirement otherwise your guessing
Great ta  Dave   ...i  since  managed  with  your  advice  to  find  part  number  for  module  and  with  that  found  one  on  ebay  uk   ...approx  55  euro  incl  postage !!! ...hopefully  should  have  it  later  this  week  so  fingers etc   crossed  and  thanking  you  again  for  your  advice  and  time   ...
Morning Frank
As I said they don't normally break, that's why there are so many for sale second user. I still have an Instinct/Doubt it is your issue, if your compressor runs but isn't lifting the car properly that is where I would start. Again get the part number this time you won't find any second user just refurbished or New
I hope it fixes things be great if it did let us know
As could only happen , courier company saying  pkg(module)was delivered  yesterday.. except it wasn't..  have checked with neighbours  ..no joy..  cant find ph no  or email addr for  bimmerpartsforless (Millane ind est Brigg!)other thing notice lately is car right down on passenger side rear now...so much so any kind pothole   causes serious 'bang'  from that corner   !!!   Trying meantime find someone here (Dublin)who would be able properly identify issue (can't afford main dealer prices)  as mechanic who normally looks after car for me is away on holidays (as could only happen )   thinking too again  about idea changing it to 'ordinary ' suspension   if it comes to it...  wondering what sort cost  kit do that might be  ??
THANKING  you again in advance
Morning Frank
I think Bimmerparts only trade through Ebay contact them through ebay and you should get a resolution
Your car, is the compressor running but not inflating the airbag ? That is the problem worn out compressor they are around £140 and you can get them from Good Auto Factors or sites like Ebay same with Airbags if you need them about £120 should get 2. I would start with the compressor, on start up does it run until it cuts out and you get the suspension warning on the dash/screen but the car isn't rising? Easy to change a real DIY job Disconnect battery, then under the rear of the car remove the plastic under tray and cover box to expose the compressor. Undo the two airlines remove the electrical plugs then undo the 3 mounting screws, compressor out. Reverse the procedure to put it back don't over tighten the air connectors. slowly lower the car reconnect the battery and the compressor will run and inflate the suspension. About 45 mins work plenty of how too's on the Nett
As for BMW specialists I think there are 2 or 3 in the Dublin area just Google them then talk to them
Hi mate. I live near bring if you need anything collecting and posting. 👍🏻
Thanking  you  for  thought  and  offer    ..  hard to  believe  but  courier  arrived  at  door  yesterday  with  module  ..almost  week  after  been  told  it  had  been  delivered  last  Wed   and  the  phone calls/emails  hassle  trying  trace  it  since    ,   went  fit  it  today  and  it   discovered  it  doesnt   !!!!!!!!!!!!  so  could  i  ask  if  anyone  knows  where  i  might  buy  kit  that  converts  it  to   'conventional'  and  does  away  with  need  for  module/compressor  etc   ??
again  thanks in  advance
Frank
Changing to springs is a simple mechanical swap take out the air spring bolt in the conventional spring you will need spring compressors to get the steel springs safely in place. However coding out the sensors and compressor control software to stop all the messages on your dash still needs doing unless your happy to drive around in a car with faults showing. A spring kit should cost around £200. Then all you need to do is as said find someone to code out the other stuff if you have someone to do that they could do a full ride height scan and tell you exactly what is wrong I have a feeling that would be simpler and cheaper???
If the Module you ordered was wrong what did you order ? If you contact Bimmerparts they will probably change it for you or give a refund. Did you check www.realoem.com to get the correct Part number before buying ? Have you had a scan Done?
      BNW X4 40i 3ltr diesel 2019, heat sheild
    2. 11
      module
      430d v 435d
    4. 5
      Upper control arm play
      430d v 435d
    • Mark Miles earned a badge
    • Mr.BKL earned a badge
    • NxhFam earned a badge
    • albertinejim earned a badge
    • StaffordSteve earned a badge
