Need help identifying burnt part on water damaged Harman Becker amplifier. Part # 9320214 - model BE B220. I am trying to repair this unit and one component is burnt beyond recognition. It has 4 pins and is SMD package.
Attached are pictures of where the component is on the PC board. If anyone has an amplifier that is model BE B220 or similar and could take a high resolution picture of the component so I can get the SMD code from it I can look it up.
Morning Dan
As it isn't a BMW Part I am not sure there will be help here, unless a member on here has come across the same issue
Maybe Google to see if there is a Harmon Kardon Forum to see if they have more information
