X1 gearbox service
Hi Darren Think about how much you have saved at Main Dealer hourly rates 😁 Plus the satisfaction of a job well done Modern cars not designed to be DIY friendly 😅 the cynic in me thinks it is a ploy to drive us towards the dealer network. They will probably tell us they would never do that, yeah right 🤣 Well done Dave -
8
2007 525i
Could also be a stuck idle control valve. Remove it and give it a shake… it should click clack noise opening freely. -
8
2007 525i
Borrowed from another site… unplug the maf and clear the codes… see what happens. i think me and greydog are on the right lines -
8
2007 525i
I have an old scanner hand held I had a body shop that I deliver paint to they ordered me a BMW MASS AIRFLOW SENSOR I replaced it on Saturday morning I did not disconnect the battery the car idled good so on Sunday morning I went for Gas and the car started to idle erratic and the service light came on so I put the old Sensor back and cleared the codes 1415 the car runs fine just erratic idle when stopped at a light Any Ideas thank you very much for getting back to me I appreciate it anything you can think of that I did wrong 😑 -
8
2007 525i
Hi Ronald. What scanner are you using? I have a cheap 110 obd unit, an autel eu705 (or something ) and a pc with bmw 1.4.0 programme on it. all give me an option to reset adaptations in the dme menu.- 1
