X5 x70 Front Differential Fault
Drivers side window switch
Check for continuity between the live at the switch and the fuse. Check the earth from the switch to the main body. you should have 12 v at the switch plug with the engine running. The wiring loom runs through the door near the hinges and can sometimes become brittle. if there is no power at the switch, make a + and - wire from a 12v battery to the switch terminals and see if the switch works. That will confirm the loom issue. -
Fuel return hose for E91 330D
Hi guys I don't suppose anyone on here has a spare below fuel return hose/return kicking about for a E91 330D you woukd like to sell? -
Hi all I've got a bmw 1 series 116i msport 2014 I was moving the passenger wing mirror an it just stopped working now I carnt use any windows or wing mirrors on the drivers side main switch I've bought a new switch an that doesn't work I've checked fuse with a multi meter an all fine Any ideas Thanks simon -
Hi Dave, Many thanks for your reply, yes i would always DIY this … I am fully aware of realoem and have indeed been researching a replacement front diff. anything i’m looking at will be factoring in new oil seals to be fitted also, along with the correct spec diff oil.. will keep this post informed of the outcome.. Dave 👍- 1
Hi Dave Welcome to the Forum Gear changes up or down should be really smooth the movement shown in your Video definately isn't right. It raises some issues for you as BMW don't repair anything just replace assemblies then retain the damaged item so few appear on the aftermarket If you aren't aware look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model. Then search the front axel assembly for the part number you need. If I recall the 8 speed transmission has 1-3.15 ratio diff but check that as I am an old bloke 🤣 Once you have the part number search onine for the best price a low milage Diff from a Dismantler may be the best cost option, I would expect a Dealer to be around £1k+ plus fitting if you can DIY then a refurbished Diff may be available I would guess £6-700 plus fluid would be my guess Most cases of Diff damage and Transfer case damage I have seen are the result of incorrect tyres or in one instance a single tyre replaced on the front (nearside new ofside around 5mm tread the difference was enough to cause damage. The E70 up to 2010 and F15 that followed were more robust in the transfer case than the E53 but the result is Diff issues Hope this helps Dave
