The plot thickens I have changed 2 Turbo's on friends cars but in both cases they were refurbished Turbo's brought as the OEM ones were beyond help. And were fairly straight forward (grazed knuckles) to change. Could the leak you spotted be coming from the Oil Feed pipe ? Dave -
5
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew -
5
Hi Andrew Are you using www.realoem.com ? The drawing looks like it or is that from the Internet? Is the turbo fitted OEM ? Dave -
5
Hi Dave, Thanks for your reply! Removing the turbo is not that challenging. The challenge is to find the right gasket.. And here I’m a bit helpless, since no.8 on the drawing does not fit there. Looks like there simply isn’t any gasket.. Andrew -
Z4 5 speed auto transmission problem
Morning Anthony Welcome to the Forum Have you checked the Electrical connector and it's sealing ring if they are not seated correctly or the "O" ring is damaged they can leak, a lot. Good Luck Dave
