2020 2 series 218i grand coupe
Engine Failed with broken timing chain
Is there Any way of making the useless heads lights better apart from fitting high output bulbs ? -
5
It's now 4 years down the line and the engine was rebuilt by a local BMW wise kid. Has been running fine now that the Cats been muted and the ECU told that the cat ran off , runs better with more mpg and now on 109K miles. -
Air bag fault
Good morning Dave Thank you for your response. I did have some work done but none was in the steering wheel or instrument cluster. I do have an airbag code 09 "Side airbag, front right" on that I have not managed to clear out yet. I did clear the fault codes 2-3 times which it did remove most of the fault codes apart from 3, 09 Side air bag, front right 28 thermal sensor for oillevel defect - BTW my vehicle does not have a oil thermal sensor 94 LED for anti-theft alarm system open circuit - BTW the red light that is on the top of the dash has never been ON. Dimitri -
Air bag fault
Morning Dimitris First the battery is in good condition ? I spoke to a friend who works for BMW in the USA he tells me that this code is often riggered when work is carried out on orther components such as Steering Wheel or the Instrument cluster. He sent me the attached hope it helps BMW_Airbag_Failure_Codes.pdf -
Vibration while ideling
Do the revs go up and down? does it feel like it’s mis firing? how bad is the shaking?
