Camshaft stuck issues
Need some help - daughters car broke down 2012 1.6 M Sport - AA said at first coil pack but them timing chain had stretched- the below is what the garage has done and now cannot find the fault we are getting desperate to get it sorted 😩😩😩
BMW 116i N13
Original faults misfire cylinder 4
Camshaft angle offset with crankshaft
Removed coil from cylinder 4 found damage, replaced coil and plug, fault cleared.
Camshaft angle offset with crankshaft reoccurred
Removed rocker cover - found timing chain loose- damage to guides
Replaced timing chain, tensioner, guides, rocker gasket
Cleared faults
Fault - inlet Camshaft stuck
Charge pressure control switch of as consequence
Removed and replaced both inlet and exhaust vanos hubs, rocker gasket
Cleared faults and retested
1/2
Fault reoccurred inlet camshaft stuck and charge pressure control switch of as consequence
Removed and replaced inlet vanos solenoid
Charge pressure control switch off as a consequence
BMW 116i N13
Cleared faults
1/2
Any help would be appreciated- the garage is still no further forward with the problem
Thanks Dave , the vanos were replaced by the garage and it’s still stuck , the frustration is that the car was actually running ok when it went in for repair, the garage is now dropping the subframe to get to the sump to see if any broken parts are causing issues in the camshaft - the daughter is a nurse and really needs a car , lessons learnt should have took it directly to a BMW independent specialist i think 😩
