Morning Tony
All fuses check OK ? If you are a DIY man then in the passenger footwell behind the covers you will find the Blower motor housing. Fixed to the bottom of the fan will be the Fan Regulator (Sometimes reffered to as the FSR) This is quite often the problem, though the blower unit itself can be changed
I would expect a Regulator to cost around £20 to £30 a complete fan around £60 to £90
Good luck
      module
      Heating in bmw g30 530e
    3. 5
      unable to figure why has crank no start 02' 330xi E46
    4. 5
      I have a 2017 BMW X3 transmission fluid
    • frankman earned a badge
      Collaborator
    • kasparsp earned a badge
    • IanW5177 earned a badge
    • Giovanni earned a badge
    • albertinejim earned a badge
