Greetings, had replace my automatic transmission with a manual 6 speeds,the clutch master have a 4pin wire… any info how to connect will be greatly appreciated
Morning Babylon
Not sure what your asking here as far as I am aware that there is and electrical connection for the Brake light switch. I am not aware of one for the clutch but am always willing to learn
Check www.realoem.com for the pedal arrangement normally if there is an electrical connection it will be identified then search for wiring diagrams for that part number.
Dave ,did find the diagram for the clutch module,only one wire going to EWS (cas) was not enable to be located
Morning
Where is your wire connected at the Clutch master cylinder cap ? or do you have a switch at the pedal pivot ?
16 hours ago, Greydog said:
Morning
The wire #4 iut of the clutch module go to number 8 on the EWS  , case solve
    2. 19
      E90 Cigarette Lighter Fuse(s) Help
    4. 19
    5. 19
    • Matt_S earned a badge
    • StaffordSteve earned a badge
    • ndsim earned a badge
    • Ken C earned a badge
