Hi Stuart
Mtec with Mintex Pads always good value as are Apec, then there is Brembo discs and pads
It depends if your only doing the Front or the whole car there are often some good deals to be had. Don't ignore your Dealer they often can be competitive and don't think the Auction sights are always the cheapest check the Factors as well.
Use www.realoem.com to get part numbers and then use Google to find the best deal
On 4/24/2024 at 1:04 PM, Greydog said:
Hi Stuart
Hi Stuart
Hi Dave, I’ve actually gone for EBC grooved discs with yellowstuff pads. Just thought it would look a little beefier whilst still benefitting from good performance and longevity.
Stu👍
Stu👍
When you say budget, what price did you pay?
Well!! It started as a budget query but after a little research and shopping around I managed to get a couple hundred pounds discount off the total price. Originally I was only going to replace the rear set but I also needed a front tyre so I’ve gone all out and purchased two from tyres to match the rear asymmetric 6’s and a full set of discs and pads. So doubled my budget but peace of mind and aesthetically 😊
Knowing the Brake are going to work and the tyres are going to point you where you aimed plus stop you is always a big PLUS 🤣
Now you can drive it like you stole it with confidence 🤣
EHJOY
EHJOY
      No boost and strange noise
      Bmw E30 Touring
    5. 8
      2007 525i
    • Ian old e36 earned a badge
    • Pezza Singh earned a badge
    • Joe Quad earned a badge
    • slick209 earned a badge
      Reacting Well
    • Dappa earned a badge
