E61 520D 2006 Drive Control System and other errors
Cush
Hi could anybody help with the problems I'm getting . When it happens the cars interior power will flash off and on including headlights the display will flash on and off some times stay off then back on and my steering will stiffen up alot like there's no powersteering. I've attached photos only other thing ive had pop up is check battery tterminals ha e checked all these and they are tight . All things clear and go back to normal when key is removed and restarted. Cheers
Morning Stephen
I was going to say battery (then read your post again) have you checked the Power Post under the bonnet is that tight?
Otherwise it is a Diagnostic session
1 hour ago, Greydog said:
Morning Stephen
Hi thanks for the reply. I've checked the rear end and all it tight I'll check the front today. My battery is a Yuasa HSB019 Silver 12V Car Battery its been registered can't be coded correctly due to being a 100ah can only be coded to a 90. Could this be the problem ?
My E53 has the same Battery, registering just regulates charging so I would check voltage at the under bonnet charging points Should be 12v+ (min) ignition on engine off 14v+ engine running. Quick thought is it registered as AGM which I believe yours will be?
Is the IBS lead in the boot in good condition
Good Hunting hope it's a simple fix
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
