Fuel leak
Ace34
IMG_0750.thumb.jpeg.89a13c5468f3be5efe3bb3e5b40782db.jpegI’ve a 05 520d I’ve changed fuel pump and level sender put them in now I have a leak from the seal I’ve put new oem seals from bmw in and I still have a leak there’s no cracks I can see is there a way it’s meant to sit in there to create a seal desperately need advice on this
Morning Richard
Check www.realoem.com the small exploded drawings will show how stuff should fit. Check the mounting face for any old gasket or imperfections. Then reassemble using a new gasket that is the way I would go
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
