Steering rack
Marky 9
Hi,
can someone please help as I’m just going round in circles. I need to replace the steering rack on my 12 plate F30 but looking online there are numerous part numbers so I’m not sure what one to buy. I’ve asked BMW but they have been less than helpful. Can someone please advise me as to whether there are different numbers for the same part.
TIA,
Mark
Morning Mark
Take a look at www.realoem.com put the last 7 digits of your Vin into the search box it should bring up your Model. Then search steering,
double click the part number and you should get a list of alternate part numbers. All of those part will be marked if they will fit. Also you will see what other models they were fitted to after fitting you will need a service code to get it working correctly
1 hour ago, Greydog said:
Morning Mark
Many thanks for the advice. I’ll give it a go 👍
      wheel fitment
    2. 8
      Front windscreen washers
    4. 8
    5. 8
    • hermit earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
    • jon green earned a badge
    • Astonred went up a rank
