120i recommended oil and plugs to use
stacy
Hi,
Bought a 1 series 120i 62 plate with 113k last night.  I'm looking to give it a service next weekend. And was hoping to get some input on the best or recommend oil and spark plugs to use please
Morning Stacy
I stay with Bosch or NGK spark plugs I use Mobil 1 or Castrol fully synthetic 5-30 grade, Oil filter Mann. Check if the fuel filter has been changed and check the Cabin filters
Hope it goes smoothly
Hi, thanks for the input.  Spark plugs were the ngk's so I changed them like for like.
 I've noticed a ticking sound when I took all the plastics off to get to the engine.  Doesn't sound like the chain, but the small pulley.  Is this a common issue with these engines?
Morning Stacy
Cabin and Fuel filters are often missed particularly once the car is outside the Dealer network (ie end of Warranty) Idler pulleys are serviceable/changeable a ticking sound with all the engine covers off could also be injectors.
      M buttons
      Steering wheel replacement
      F30 A-pillar install
    • amebb went up a rank
    • Conmil earned a badge
    • Loulou earned a badge
