Hi, does anyone know the part number of part name for the inside of the engine compartment bulk cover at back, mine is broke and let’s water into the top of engine , I’ve heard this can get into the injectors and make them go wrong
thanks
Morning Aaron
Check www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model. Then check the sections for what you need
I know of 2 people who have brought from Ebay and all fitted OK though I have no idea if it was the same supplier
hi all,i fitted the 3 piece cowling today, it was straight forward to do,i dont think they will last because quality is bad, plastic is very hard like it will go brittle and snap again. holes were slightly off too, where they fit the middle section there is a gap in them were water will drip under on to engine, i was going to put some rubber sealant to stop the water, but i might need to remove soon to replace no.6 injector, looks better tho! found out under the cowling on drivers side is were the brake fluid tank was and passenger r side was the pollen filters!
Everyday is a school day 😂
Spoke to one of the guys who fitted the same parts he noticed a gap and super glued a rubber flap to cover the gap (he cut it from an old cycle inner tube) His have been in place for almost 18months now with no issues, so I guess it is how often you take them on/off and how careful you are.
Glad you had no issues
      No boost and strange noise
      Bmw E30 Touring
    5. 8
      2007 525i
    • Ian old e36 earned a badge
    • Pezza Singh earned a badge
    • Joe Quad earned a badge
    • slick209 earned a badge
      Reacting Well
    • Dappa earned a badge
