840ci fog lights always on
razimm
The fog lights on my 1997, E31, 840ci are always on, (even the dash indicator light) even with the ignition turned off. I also pulled the fuse and they stayed on. They are on eventhough the headlights are off. I finally disconnected the bulbs so as not to drain the battery. I think the problem may be with the Light Control Module (LKM) part number 61351383412. I can not find another module. Does anyone know of a source or some place that can diagnois and repair my module. Thanks for your help.
Rudy
6 hours ago, Greydog said:
Morning Rudy
Not sure where you are in the world, if you are in the UK there are several repairers
Try ECU Testing in Nottingham or Cartronix both have Websites
Good luck
Thanks Dave. I am located in the USA but if I don't find a source here I will contact those you suggested. Thanks for your help.
Rudy
Morning Rudy
Another thought in the UK there is an online list of BMW Dismantlers I have used Quarry Motors in Sheffield UK several times maybe an email exchange may help
If you end up changing the LCM/FCM you may get a tamper dot against mileage don't worry it is a fairly simple fix
      Amplifier replacement.
    5. 3
    • Danny428F33 earned a badge
      Reacting Well
    • damiansteel earned a badge
    • Loulou earned a badge
