Needing some advice on some 2004 325i issues..
Amplifier replacement.
Hi All I have a BMW 428i F33 2014 model. The audio amplifiers has been replaced. I bought the car second hand, after less than 3 days the audio amplifier popped and it was replaced by the garage i bought the car from (at no cost to me). However it has blown again. All sounds, both audio system and the normal bings and bongs have all stopped. I have taken the unit out of the boot and discovered it has been replaced with an Audison Bit Ten Signal Interface Processor bit drive and a Hertz Mille ML Power 5 5 Channel Amplifier. It is clearly the Hertz unit that has fried. Both 40amp fuses are welded in place and the unit stinks of burnt electronics. The Audison unit still gets power and appears fine. My question is, do i need to replace the Hertz unit with the same unit again? They are just over £600 for a new one, or can i use any 5 channel 900w amplifier? ( i know next to nothing about car stereos) Has anyone else had the same or similar issue? I don't want a mega pounding, super maxed out stereo, i just want the car to bing and bong again and be able to listen to Radio X on my 7 minute drive to work! I may possibly have included some pictures below? Thanks for your expertise and guidance 1000012573.heic 1000012574.heic 1000012575.heic 1000012576.heic -
Hi, just got a new 230e Active Tourer and joined the forum. Love the car, especially when running on electric motors only, but it has an issue with the curved panel control display that doesn’t always switch on when I start up but then randomly starts up 10 mins later. BMW dealer hasn’t seen it before so it’s booked in for an inspection next week. Has anyone else seen this on on any of the new plug in hybrids with the same display panel? -
Front windscreen washers
Thanks for the reply, i will get hubby to check this next weekend when he's back from his work trip. Thanks for your help. -
wheel fitment
Absolutely correct my E53 runs 9.5 x 20 Front and 10.5 x 20 Rear and the E70 is as yo say 10 x 20 Front 11 x 20 Rear. Not really necessary on a 4x4 but BMW Designers like the looks 🤣🤣 ( and so do I) Hope you found what you needed Dave -
Morning Donna Has the pump always been like this or has it come on over time? I think I would check the voltage at the Pump connectors so you can compare front and rear perhaps swap the connectors. If the pump action changes when the connector is swapped then the wiring needs checking and the connector needs cleaning with a good electrical contact cleaner. Dave
