Failed start becoming more frequent
Jonsnow42
So somewhat recently when I go to start the ignition the car will go to start up but then putter out after 1 second and everything shuts down. I’ll wait 5 seconds and try again. Sometimes it will keep cranking but most of the time it will just start up normally after the failed attempt. Then run completely fine.
I would say the failed start happens once every 30 starts. I’m kinda at a loss as to where to start.
Morning Ryan
If your car is in fact a 2023 X3 then the obvious place is the Dealer as it is under Warranty or should be.
If your car is older and no longer under warranty you need the help of someone or a Garage with BMW diagnostic capable equipment
      Front windscreen washers
      wheel fitment
      wheel fitment
    • Loulou earned a badge
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
