Headlight error code
JT12
Hi all. Recently purchased LED bulbs for my x1, installed them and then realised if it’s not halogen then bmw aren’t too happy. Long story short I bought resisters after finding out they wouldn’t work without them. Installed the resisters to the led bulbs and I’m still getting the error codes come up. Any advice? Thanks.
Morning Jack
If you haven't already put your Halogen bulbs back, do you lose the warnings ?
That is a simple way of making sure there isn't a fault. Then check your LED lamps most of the LED lamps I have seen have resisters built in if not check the resistors you have brought are correct rating and fitted correctly
      wheel fitment
      Front windscreen washers
      wheel fitment
    • Loulou earned a badge
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
